Tuning range: FM, MW
Power output: 20 watts per channel into 8Ω (stereo)
Frequency response: 5Hz to 100kHz
Total harmonic distortion: 0.3%
Damping factor: 25
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 73dB (MM), 90dB (line)
Output: 150mV (line)
Speaker load impedance: 4Ω (minimum)
Semiconductors: 3 x FET, 5 x IC, 17 x transistors, 29 x diodes
Dimensions: 435 x 144.5 x 314mm
