Аудиокомплект SONY винтаж
Сообщение igor_bolotov » 13 апр 2015, 12:42
Продается комплект из 3 предметов:
1. Sony EL-5
Очень редкая Елькассетная дека:
Display ◾3-Digıt Mechanical Counter
◾Analog Needle Meters
Exterior ◾Front Loading
◾Orientation Left
◾Silver Finish
Head Configuration ◾2 Head Design
◾4 Track / 2 Channel
Power Requirements ◾Alternating Current
Speed ◾3¾ ips - 9.52 cm/s
Tape ◾Manual Tape Equalization
◾Chrome Tape Capabılity
◾Ferro-Chrome Tape Capability
◾Normal Tape Capabılity
◾Manual Tape Type Selection
General ◾Stereo
Transport ◾Solenoid Control (Mechanism)
◾Mechanical Tape Loading
◾Auto Shutoff
◾1x Motor Mechanism
Connectivity ◾2 Mono Microphone Inputs
◾AC Power Connector
◾DIN Input/Output Connector
◾Front Input Connector
◾Headphones
◾RCA Input/Output Connectors
◾Wired Remote Control
Indicators ◾Record
Noise Reduction ◾Dolby-B Noise Reduction
◾MPX Filter
Operation ◾Timer Recording/Playback
◾Memory Play
◾Memory Stop
◾Full Logic Transport Control
Preamplifier ◾Headphone Volume Control
◾Individual Input Level Controls
◾Microphone Level Adjust (Left/Right)
2. Sony TC-K7II
Топовая кассетная дека
1. General
System: Compact Cassette
Colour: 1=Silver, 2=Black: 1
Power consumption: 35 W @ 120/240 V
Cassette Recorder
Motors: 2 (servo)
Heads: 2
Track System: 4/2
FF and Rewind Time: approx. 70 sec (C-60) sec.
Tape Speed cm/s.: 4.8 cm/s.
Tape Speed ips: 1-7/8 ips
Wow and Flutter: ±0.12 (WRMS)
Frequency Response Normal: 30-13,000 HZ
Frequency Response FeCr: 30-16,000 HZ
Noise Reduction: Dolby B
Signal-to-Noise Ratio: (FeCr) 59 (A weighted)
Signal-to-Noise Ratio B: with Dolby B (FeCr) 69 (CCIR)
Bias Frequency: 105 kHz
Input Impedance Line In: 100 kΩ
Input Sensitivity Line In: 60 (-22 dB) mV
Output Impedance Line Out: 100 kΩ
Output Sensitivity Line Out: 775 (0 dB) mV
2. Physical
Dimensions in Inches: 16.93 x 6.69 x 12.20 (w) x (h) x (d)
Dimensions in mm: 430 x 170 x 310 (w) x (h) x (d)
Weight in lbs: 22.05 lbs
Weight in Kg: 10 Kg
3. Sony RM-30
проводной пульт дистанционного управления, подходит для этих обеих дек. В идеальном состоянии, как новый.
Все работает отлично для своих лет, косметика аппаратов на 4, пульт на 5. Обе деки прошли полную профилактику и отстройку!
Цена 1200 долларов. Для Членов Клуба особая цена.
Продаю в связи с тем что, перешел полностью на винил и катушки в аналоговом сегменте аудио.
