Drive system FG detection quartz lock core less DC direct drive
Rpm 33 1/3, 45 rpm
Wow flutter 0.005% (rpm FG method), 0.015% (WRMS)
Signal-noise ratio 80 dB (DIN - B)
Starting quality Within 1/2 turning
Starting torque 1. 4kg -cm (maximum)
Inertial mass 560kg -cm2
Rpm deviation 0.002%
Turntable Diameter 35cm aluminum die-cast, weight 2. 9kg (seat included)
Tone arm type Electro- dynamic servo TH system straight S letter pipe exchange type
Effective length 254 mm
Stylus pressure adjustment range 0 - 3. 0g
Installation cartridge weight Straight arm: At the time of 4.5 - 10 5g/sub weight use 11.5 - 17. 5g
S letter arm: 8 - At the time of 14g/sub weight use 15 - 21g (the shell is included)
Arm height variable range Reference level + 5 mm and - 2 mm
Cabinet finish Rose wood pitch mirror finish
Rated electric power consumption 12. 5W (electric supplies control method standard)
Size 495W × 187H × 405D mm
Weight 12. 3kg
In addition Full automatic mechanism attachment and dust cover attachment
Цена 1100 долларов (возможен торг после осмотра и предусмотрена специальная цена для членов Клуба)
